Copy eq effect styles
Naor222222
Post by Naor222222 »
Hi when I copy a style to a set. So there is a difference in eq and volume between the style I have in the set and the new style I downloaded to the set. :| :|
Re: Copy eq effect styles
A style is copied 100% as it is without any eq/volume/fx being touched, UNLESS
you're converting it to a lower model.
If you're doing a set for the same models, then the only difference can be due to your GLOBAL MAXX EQ settings.
