Naor222222
Posts: 1 Joined: 21 Nov 2021, 10:42
Post
by Naor222222 » 21 Nov 2021, 10:50
Hi when I copy a style to a set. So there is a difference in eq and volume between the style I have in the set and the new style I downloaded to the set.
Posts: 901 Joined: 23 Feb 2014, 11:44
Post
by Admin » 25 Nov 2021, 18:01
A style is copied 100% as it is without any eq/volume/fx being touched, UNLESS
you're converting it to a lower model.
If you're doing a set for the same models, then the only difference can be due to your GLOBAL MAXX EQ settings.
