Would it be possible to add a feature to Sample Manager that detects and deletes multisamples not linked to any sounds?
At the moment, my KST set contains 977 multisamples, and I have to manually select each one to check where it is used and then clean up the unused ones. This process takes a lot of time.
Detect not linked Multisamples
Re: Detect not linked Multisamples
I discovered that when all multisamples are selected, the system generates a report indicating where each multisample is used. To streamline the cleanup process, I currently export a TXT report of all multisamples and perform a search in a text editor for the phrase “used 0 times.” This approach makes identifying unused multisamples significantly easier.
