Problem with PA5X styles (converted from pa4x)
boki981
Post by boki981 »
Greetings to the team
I ran into a little problem converting the set from my old keyboard korg pa4x to the korg pa5x.
In one rhythm, the commands for fill in (both automatic and separate) behave strangely...
Sometimes fill in plays everything with all elements, and sometimes only strings and bass are heard...
Is there an option to copy it again or fix it in pa manager 5.1
Thanks in advance...
Re: Problem with PA5X styles (converted from pa4x)
Unfortunately at this stage, there isn't much PA Manager can do in relation with Conversion problems, as those are related to the PA5X OS.
Although you can try reSaving the Style via the PA MANAGER, by entering Style Properties, changing any value (i/e volume) then Save the Style.
Or even try resaving it via the PA5X through rec>Edit Style and see if any of that helps.
Could you send us the PA4X style perhaps so that we could convert and see what is happening?
