Font-size and responsive design
benzitre
Post by benzitre »
Ιn the future, it would be a great idea , if you made your application with responsive design.
For example, I use Windows with a 125% screen resolution, but the application is not visible at the bottom,
the taskbar covers it, or I don't see the part that shows the memory on top.
Also if it is possible to have an option to change the text size of the letters eg 16px, 20px, 30px
because at 100% the letters are small enough if you work for hours.
Thank you very much :D
Re: Font-size and responsive design
Yes, we can improve the app with improved DPI support, however, the general UI is already quite full with limited space. If we provide font size option, I don't see how we could fit everything on screen.
The Memory window is also a Floating Window, meaning you could drag it around so it doesn't become hidden under the task bar. This is something we did for such cases.
Perhaps a quick solution would be to lower down your screen resolution (which would enlarge your screen) and then lower your screen DPI to 100%, and this would resolve most issues.
