Features needed for Style Copy Operations with out STS
CKO
Post by CKO »
Hello KPM Team,
I would like to use KPM to copy only the styles from a Korg Pa 1000 set, which works, but I would like to only copy the styles without the 4 occupied STS entries.
or a way to delete (empty) the 4 occupied STS.
This would avoid unnecessary multi-sound importing.
On the STS tab I only have copy, paste and rename, there is no delete or set to empty.
Can something like this be done with the KMP?
BR, Cengiz
Re: Features needed for Style Copy Operations with out STS
Copying the 4 STS Sounds is Automatically NOT enabled by Default. So that they're not copied.
You can take a look at the settings on the Copy Options Menu. Here's a Video: https://www.youtube.com/watch?v=0LFvs4KTb0c
You can also Individually right click on any of the Tracks (UP1/2/3/LOW) to Default the Sound to a Factory Sound. There is no way to DELETE/REMOVE these. There must be a sound assigned to them that's why there is an option to default to a Factory Sound.
