Question about copy styles about samples
etnomor
Post by etnomor »
I have i set with samples converted samplerate and maked samples from mono to stereo. I want now to copy styles with marked "copy sounds" from original set from the non converted set. Will that copy that samples or will that be replaced on my set with the same name that already exist? Or even not copy the samples because it is already exist?
Re: Question about copy styles about samples
It depends on the sample ID's. If they're converted, then they now have changed ID's meaning when you copy from your original set, it won't detect them as existing in your SET, but it would import the original ones from the SET that you are copying from.
