VERSION 3.3.7301 Sound from pa4x to pa2x
Re: VERSION 3.3.7301 Sound from pa4x to pa2x
There is no MUTE option with the sounds. Do you mean the VOLUME of OSC LAYERS = 0 ?
Can you please upload 1 or 2 Sounds so that we can take a look at the issue?
Just to confirm are we talking about Sounds that use ROM Samples?
Because those are set to 0 by default.
You can't be converting sounds from 4X to 2X that use ROM samples. The conversion works for RAM Custom User DrumSamples/Multisamples only.
Will confirm / test and get back.
A new update has been released v3.37505 which should have fixed the issue.
