Comparability
NativeAngels
Comparability
Post by NativeAngels »
Is the Pa Manager compatable with the Pa50sd ?
Re: Comparability
NativeAngels wrote:Is the Pa Manager compatable with the Pa50sd ?
Theoretically PA50/PA80 files are the same, so in theory it should be compatible, unless the pa50sd uses a format which I'm not aware of?
Try out the demo & see how it behaves when you load the files... It's so hard to get hold of such old sets these days to test.
NativeAngels
Re: Comparability
Thank you I will get back to you with the results.
