Error importing wav [RESOLVED] v2.2+
gewa
Post by gewa »
From sample manager when importing wav file error dialog comes up.
See attached
test_c4.zip
(94.58 KiB) Downloaded 1650 times
Re: Error importing wav
Can you attach the .WAV file you are trying to load?
gewa
Post by gewa »
I have attached zip in my original post. Btw: I can load the same file into PA3x no problems.
Having examined the file, I can say this error will fixed with the next update.
Bili2015
Post by Bili2015 »
Hi there,
the same issue happened to me yet please bring an update !
Screen Shot 2015-12-07 at 13.50.24.png (12.29 KiB) Viewed 38967 times
gewa
Post by gewa »
I did few more tests, with different wave files, and no matter what the error is the same. Even when you export multisample from the manager and try to import back the same wave file the errors happens.
Try this: Click on Start>Control Panel>Region and Language>Administrative>Change system Local>>English United Kingdom
Restart your PC and see if that helps ?
gewa
Post by gewa »
Admin wrote:Try this: Click on Start>Control Panel>Region and Language>Administrative>Change system Local>>English United Kingdom
Are you serious? I dont want to change my default locale, so I can import wave file. You are being very unprofessional, instead of providing a proper patch for it, you suggesting system modification.
It's a temporary fix to see if it fixes the problem. If it does, then we'll know what the problem is.
Ofcourse there will be a patch, but the problem needs to be identified first.
gewa
Post by gewa »
I have tried that and does not help at all.
