Editing ROM Sample names
midimusa
Post by midimusa »
Hello.
Can You in future make possible to change the ROM sample names (and indexes)?
Right now the sample numbers and names are totally different regarding the Manager and my PA600 (V1.20), and maybe Korg will do more upgradings.
It can be a (Export, import a list) cfg, ini, or txt (what ever) file that is editable, so i can change the names of the samples.
Here is one Multisamle Table (Thanks Rick Stirling who is uploaded that one) - that list fits with my PA600 ROM (not drum) samples.
It includes a PA4X ROM sample names as well.
PA_MultiSamples.rar
Extraction from Korg User Manuals by Rick Stirling Nov 2, 2015
(35.28 KiB) Downloaded 3114 times
Re: Editing ROM Sample names
The Database KORG PA Manager uses is exactly the same as in the provided list, which is the actual list from the Manual.
Just to make sure, have you selected the Keyboard Model / Environment Mode to PA600 when you load the SET?
midimusa
Post by midimusa »
No. It Is Not!!!
For more. There was no any changes in that list.
Is that possible to bring it out, peronally i think it is better way to give the people let customize their samples banks.
What's happening is, the Keyboard has an 'internal re-mapping table' of which the PA Manager has no access to.
So although a ROM Sample 233 is an Accordion on a 3X , 233 is a trumpet on the pa600. But the keyboard knows this and remaps it internally when you select the sound.
