The Pa Manager crashes when clicking on "Generate Report" on one of the style.
Please screen shot.
Pa Manager crash on Style Manager [RESOLVED]
- Attachments
- crash report.JPG (120.47 KiB) Viewed 23639 times
Re: Pa Manager crash on Style Manager
I didn't use the Pa Manager for longtime because of the bugs that I previously reported. So I modified my set several times on my keyboard, so I think now it would be useless for you to debugging and testing this set since it is not the same set anymore.
I cannot use anymore the Pa Manager for merging styles till the bugs are fixed.
Please see the text below (just for reminding you) Copied/Pasted from other topics:
Re: No Reference to Sample in PCM
Postby Admin » 09 Jul 2015, 14:56
Ok, having explored the SETs, I found the problem.
Currently this is already a known bug with Certain old PA1X DK Sounds.
TM.Kit 16, along with most of the SET has Sounds from the PA1X version, despite the SET being a PA3X/900 Set!
So there are currently 2 options.
This problem is fixed and things should work fine with the Next Update, which is coming in the next few weeks.
To resolve the problem now however, you should load the original SET on the keyboard, and re-save each of those DK's by entering the SOUND Mode, choosing the DK and re-saving the SOUND, so the keyboard updates and saves them in the PA3X Format. Save/Export the SET and then you can use the Pa Manager to copy/paste from between sets.
Best Regards
Best Regards
The above problem has NOTHING to do with the PCM problem. That was related to the SOUND Manager and Samples. This is the STYLE Manager / STYLE Properties. They are 2 different things.
So, if you have the STYLE, please send it for debugging and error checking.
