Hello there,i would like to know if i can convert sounds and drum kits saved in user sound and user drum kit,created in PA3X which have samples or not.
I have PA2X and i want to load some drum kits with samples and some user sounds with samples from PA3X. Can i convert and load in Pa2x?
Convert user sounds and user drum kits from PA3X to PA2X
Re: Convert user sounds and user drum kits from PA3X to PA2X
Currently with v1, this is not possible. Hopefully v2 will be able to do this. So check back soon when version 2 arrives.
Thank you for reply and i will wait V2. If that will not be possible in v2, i will write in the request topic
Hi,krissna wrote:I tried to merge some sound from pa3x to pa2x set, completed and saved
While I opened the merged pa2x set, it detected as Pa3x set
Do you have the same problem ?
When you reopen the new SET with the PA Manager does it detect as PA3X ?
Can you zip and attach / mail me the SOUND Folder Folder to take a look please?
Same Problem .
Hi,hakibit wrote:Same Problem .
This topic is a year old and in regards to version 1! We are now in version 2.2 and this issue long been fixed.
What is the problem exactly?
Pa2 Setime Pa3 den DK cekiyorum.Buraya kadar hersey tamam.
Seti yedekliyorum.
Ancak bu seti birdaha acinca bu bir Pa3 setidir diyor... ?
Seti yedekliyorum.
SETI www.wetransfer.com'a yukleyip, bana yollayabilirmisin ? Ve hangi DK bunu yaptigini iza edebilirmisin?hakibit wrote:Pa2 Setime Pa3 den DK cekiyorum.Buraya kadar hersey tamam.
Seti yedekliyorum.
Setimin boyutu 256 mb yi geciyormus.
Tahminen onun icin Pa3 Seti olarak algiyormus KPM
