KORG PA Manager v5 | Coming Soon
News & Updates for KORG PA Manager.
KORG PA Manager v5 is Coming Very Soon.
With lots of great new features on the way, including KORG PA5X Support.
YouTube Video:
https://www.youtube.com/watch?v=4Dd4T1srGSg
Re: KORG PA Manager v5 | Coming Soon
If I have a PA3X Set, can I convert it to PA5X with this new version?
valimaties wrote: 07 Jul 2023, 20:18 If I have a PA3X Set, can I convert it to PA5X with this new version?
No. These are 2 very different systems now.
Only future OS updates can have that ability.
Basman Zuhair
Post by Basman Zuhair »
good job bro
wish you all the best
Admin wrote: 08 Jul 2023, 11:42
I don't know very good this soft, because I don't have it, I wanted to buy a licence, but wasn't there a function that could import from older version to newer in this soft? For example from PA3X to PA4X? I think I saw this thing in your program, but maybe I'm wrong..
So, that means now it could help only to manage multiple sets, to combine them, and so on? I thought it will be also a conversion, for example to load a style from a PA4X or PA3X set into a PA5X set. This could be a very useful feature. As long as you read the new style, to be able to know which sound is used and from which location, I thought it will be an easy way to "import" a style from an older version to PA5X style type...
Maybe you will think of a solution to that, it will be a BIG feature of this software!
Best regards,
balkan
Post by balkan »
We're waiting.. Also for the guy above, you can convert the set first on PA5X into .KST and then copy whatever you want into your own set.
It's simple.
valimaties wrote: 11 Jul 2023, 21:44 I don't know very good this soft, because I don't have it, I wanted to buy a licence, but wasn't there a function that could import from older version to newer in this soft? For example from PA3X to PA4X? I think I saw this thing in your program, but maybe I'm wrong..
Best regards,
Hi Vali,
In general terms yes, you can import between PA80-PA4X.
However, as mentioned in our previous post, that the PA5X is a totally different system.
It's like petrol and diesel.
2 Very different systems that are NOT easily mixed and combined now. It's all changed. Anything before the PA5X was under one roof. Now it's a different system.
Hi Admin.
As I mentioned, practically what I wanted is to convert from an older version (PA3X, PA2X...) to PA4X, as long as PA5X has an internal conversion tool to import from PA4X, is enough. This was because I had a PA3X couple of years ago and when Genos came on the market I switched to Yamaha. Now I have both Genos and PA5X. And I need some styles from PA3X. If the new version of this soft will keep the conversion from older versions to PA4X, that's all I will need. The rest of the job will do PA5X keyboard.
Edit: Do you know when it will be released v5, approximately?
Regards,
As long as you have a 4X SET, then the 5X would convert it to it's own .KST format.
Release should be soon hopefully.
KorgHollywood
Post by KorgHollywood »
Hi!
I Hope all is well
Is there any update on when v5 will be released?
And any chance we’ll see it available for Mac as well?
Thanks!
