Imporing Samples (Drum)
Post by midimusa »
What is the difference when in "Sample manager" I import Wav files - there are "categories" Bass Drum, Snare Drum, Hi Hat, Toms etc. ...
How they ruling or how they fill effect in future using the samples in sounds.
Re: Imporing Samples (Drum)
It's to differentiate the Type of Sample you are importing, so that it can be indexed accordingly.
In previous models, certain selections would only be available when creating a DrumKit for instance and some only in MultiSample mode.
GarryGet
Post by GarryGet »
Admin wrote:Hi,
Ok, that makes sense then. Thanks.
Post by midimusa »
Sometimes importing .Wav files i get this error "Error @ToLong"... .Yes, KPM loads them and there are no problems. Just curious what this means?
I have tried many different variants for samples (even without any adds in file like genre, name etc.), but sometimes anyway this message comes out.
I import normally 48kHz or 44.1kHz 16bit samples.
BTW. Importing many samples at once is very handy and works very well
Import DrumSamples Error1b.jpg (19.79 KiB) Viewed 39897 times
Import DrumSamples Error1a.jpg (17.98 KiB) Viewed 39897 times
Import DrumSamples Error1.jpg (9.75 KiB) Viewed 39897 times
That shouldn't be a worry and still imports the .wav normal as you've found out.
It seems something todo when it reads some data that exceeds some limit.
Can be ignored for now.
Jameses
Post by Jameses »
the problems Can be ignored for now.
Issue has been resolved with update v3.3.6410
