Feature to empty preLoadBuffer
sevinunu
Post by sevinunu »
Hi dear team,
one feature might be needed by others probably, would be clearing of the preLoadBuffer at once (as a Menu point).
This helps a lot when merging sets and defining later on what samples should be loaded into Buffer instead of keeping an eye on every copy operation from Set A to Set B during the merge operations.
Thank you so much and as always keep on the great work! :-)
Best regards
Re: Feature to empty preLoadBuffer
Not a bad idea. This could be implemented.
