multi sample streo bug [RESOLVED]
yuda_
Post by yuda_ »
Hi, I edited and organized my stereo samples into multi-samples using the PA Manager, and after loading them into the keyboard, the first sound in the multi-sample works perfectly, but everything after it only works on one side (it’s supposed to be stereo)
I tried creating a new multi-sample with the same sounds directly on the keyboard, and everything worked perfectly, which means that something in the PA Manager is causing the problem
thank you!
Re: multi sample streo bug
How did you create the MultiSample.
Did you import individual STEREO .wavs?
or import a .KMP ?
yuda_
Post by yuda_ »
import individual STEREO wav to pa manager
Can you upload a test .KST with a few samples please as we can't replicate the issue.
I'm wondering if some of the WAV's were MONO?
yuda_
Post by yuda_ »
Where to send the set?
yuda_
Post by yuda_ »
Admin wrote: 29 Aug 2024, 22:02 upload to: www.wetransfer.com
sent
we have identified the issue, it seems the R channel Volume becomes ZERO.
This will be fixed with the next update.
