Kbd set not copying correctly? [RESOLVED]
saki
Post by saki »
Hi, I wanted to copy the Kbd sounds from a Pa 4 set into my Pa 1000 Expanded version.the Pa Manager 5.1 does everything right.but when I load the complete set into my Pa 1000 afterwards I don't see my kbd set sounds where I copied them.the entries are empty.they appear under sound but not in my perfomace where I want them in.what is the reason for the other 5.1 version or is it the Expanded version 1.5.1 of the Keyobard? Thank you
Re: Kbd set not copying correctly?
Did you check the saved SET if there is a folder called KEYBOARDSET and are there any files in there?
Either that's not being saved or not being loaded in to the keyboard.
saki
Post by saki »
Yes, they are available in the folder
That means, you haven't loaded the Performance/KBDT SET in to the keyboard. Hence why it's not showing.
