USB Protected Samples - Cannot Transfer to PA5X
kmatheou
Post by kmatheou »
This is the situation. I have had a PA4X for 7-8 years love it... I would like to use many of the sounds and styles on the PA4x on my new PA5X...
I have sounds that I bought a wile back that need a USB key lock to be on the PA4X for the samples to work.. OK.. Now I created a scaled down version of teh sounds and styles in the KPM 3.3v... when I look i the Sample Manager. I notice that some samples are locked. I put my USB key in the computer that has the KPM software, but things do not get unlocked.
Next thing I trued is to save the set with the identified but locked samples, and transfer them to a PA5X format, per the import instructions for the PA5x. What happens is I get an error - forgot the name.... I have tried have the USB key in the PA5X while the import occurred and without.. I still get an import error.
My question is... Can I import files into the PA5x while locked? Or do they have to be unlocked first? How do I do that with the USB key? Or am I just sol ?
Thanks,
Taki
Re: USB Protected Samples - Cannot Transfer to PA5X
The PA Manager does NOT unlock the samples even if you do have the USB connected to the PC.
The problem is, the PA5X does NOT support & import locked samples.
In other words, there is no way to get 4X locked SETs to work on a PA5X.
tasdiastello
Post by tasdiastello »
also can someone please tell how to connect my pa5x to the korg pa manager so i can edit styles and sound ..thanks
tasdiastello wrote: 22 Mar 2024, 11:38 also can someone please tell how to connect my pa5x to the korg pa manager so i can edit styles and sound ..thanks
Why are you not creating a New Topic, but rather post in to random posts that are not related to your question?
Next time please post as a new topic.
As for the question, you do not connect PA Manager with the keyboard. It is used externally.
Please go through the Tutorials to find out more: www.korgpamanager.com/tutorials
