Filtering in Sample Manager mode [RESOLVED]
apokorg
Post by apokorg »
Hello, can I offer some feature maybe in the futures updates, is it possible making in Sample Manager mode, sorting the multisamples, samples by duration, file size, for example clicking on File Size to sort the files from highest to lowest or vice versa, same for duration (length of the sample) would be very usefull for checking which MS or samples are taking most of the memory so we can for example trim them down and set shorter loops etc, thank you, keep up the amazing job you are doing 😊
Re: Filtering in Sample Manager mode
We've had a few requests on this, so it is something that we will consider on future updates.
etnomor
Post by etnomor »
Very interested about this option to easly organize the sounds. If you can bring this option we should very happy about this feature.
This is now already possible with v5.
etnomor
Re: Filtering in Sample Manager mode [RESOLVED]
Post by etnomor »
Yes it is but not on all tabs, like sort on samplerate. Also i like to sort on mono/stereo by drum kits. Sort on Category etc.. also not possible right now. It is wel needed.
Maybe an option to bring filtering sort on all tabs possible because we are using all tabs.
