Copy styles [RESOLVED]
Mohammed73
Post by Mohammed73 »
Hello Admin and all ,
I just faced a new issue while converting a pa4x set to pa1000.
I selected some of the styles from the right and moved them to the left and it loaded the necessary samples and sound, however the used memory on the bottom did not change it remained at 0 bytes from 300 mb .
I tried it few times and even restarted my computer and same thing happened and saving the set made a small size set with no user sounds and samples .
Is it something normal ?
Re: Copy styles
There could be few reasons to this.
1) You've loaded the SET and it shows 300MB, but you're missing the MULTISMP Folder or it's Empty?
2) The style you're taking doesn't use any USER Sounds/DK's with Samples, but only Factory Sounds
3) The Sounds already exist on your SET (left side) therefore there is no need to re-take the same sounds again.
Mohammed73
Re: Copy styles
Hi admin,
Thanks for the quick response!
You are absolutely right , the set did not even have a multisample folder and as per usual I was trying to use it before checking the contents of the set.
Hope you stay safe!
