Pa600 performances
anthour57
Pa600 performances
Post by anthour57 »
Hy
When i load my PA600 set into the manager and then change the model from PA3X to PA600 some sounds are not found (Factory, Legacy or GM).
If i don't change the model the sounds are present but are not in my PA600.
Is there a problem with the sounds adresses? for example 121.9.49 must be changed to 121.0.49 to get the right sound in the manager's list.
Thx.
Re: Pa600 performances
Your SET may be exported from a PA600, but the Style/Perf/Pad that is using those sounds was most likely created on a PA3X.
Even so, the keyboard may also be doing some internal remapping when sounds are not found. i/e from: 121.9.49 to 121.0.49
The sound 121.9.49 does not actually exist on a PA600. Only the PA900/PA3X/PA4X have this sound.
