Today I just bought and activated the Korg PA Manager through your website.
It looks great however I noticed that when I loaded my Styles, it does not show the customized Favorites names.
In my set I've already renamed some Favorites but when they are loaded into KORG PA Manager, it shows the Favorite numbers (like Favorite 1, Favorite 2, etc).
Am I missing something?
Any help/assistance would be appreciated.
Not showing customized Favorites names [RESOLVED] v2.2+
Re: Not showing customized Favorites names
On the STYLE Manager window, you will see an A icon next to P1, P2, P3, P4, on the bottom left of the Style Selection window.
Click on it, and it will toggle between Standard FAV01, FAV02 vs The names you've renamed them tabs to.
Best Regards
Best Regards
Thanks for your reply.
Indeed I clicked on A letter (Load Names) on Style Manager after loading my set but it does not still show the Favorite name.
The only change I see after clicking on A letter, it changes for example Favorite 8 to Fav 8, but it doesn't load the Favorite Name that I see on my keyboard (Pa 900).
Regrds
Regrds
I've already replied to your post regarding the solution with Favorite name issue (it is not working when clicking on letter A) but why I don't see my reply in the forum.
Is there any problem with the forum replies? I would appreciate if you can answer because I am in a hurry and I need to resolve this problem.
Is there other more practical and faster way to communicate with you regarding the issue with Korg Pa Manager?
Your first 2 post's must be Approved by a Moderator before they are posted on the forum, which is why you don't directly see any posts.
Now this you reached 2 posts+, your future posts will directly be published without having to be approved by a Moderator.
Back to the question: Are you sure the SET actually has the STYLE Banks renamed? If clicking on the A doesn't reveal the names, the perhaps the Names are not actually stored? or could a possible bug.
Could you forward/attach your Global & STYLE Folders please so I could investigate further?
Best Regards
Best Regards
Thanks for the clarification regarding the posts.
I am attaching the Style and Global folders for your review.
Thank you
Yes, I perform with different singers every week end and I renamed some Favorites with the singer's name.Are you sure the SET actually has the STYLE Banks renamed?
Thank you
- Attachments
- GLOBAL.rar
- (5.08 KiB) Downloaded 2005 times
- STYLE.rar
- (840.82 KiB) Downloaded 2075 times
Thank you for attaching the example SET.
I can confirm that it seems to be a Bug in the software, that isn't correctly picking up the names.
This will be resolved in the Next update.
Best Regards
Best Regards
Thanks for your reply. Hopefully will be fixed with next update.
I have another post regarding Samples/PCM in the forum that I would appreciate if you can take a look.
can you also give option to rename banks?
including Factory.
including Factory.
Possibly in the future at some point.Nemik wrote:can you also give option to rename banks?
including Factory.
