STYLE AUDITIONING......
paul
Post by paul »
Just wondering if this feature will ever be made available soon :?: . :cry:
Re: STYLE AUDITIONING......
paul wrote:Just wondering if this feature will ever be made available soon :?: . :cry:
Hi Paul,
Hopefully one day perhaps we shall consider such option for future versions.
In terms of time frame, I'm afraid mentioning anything at this time would be unreasonable.
We'll just have to wait and see what future versions will bring.
Best Regards
midimusa
Post by midimusa »
I think that this is (in my opinion) impossible and unnecessary because You will never hear how it sounds on Your KB reallly.
There are lot of things and dependings in the styles that can not be transferred thru MIDI (USB MIDI) to Korg, even worse, listen that style using another (computer) soundcard gives you all most nothing about that style.
For example (if You did not that before): You can "Play style" using EMC Style Works (http://www.emc-musicsoftware.de/KorgPa/ ... PaDemo.zip)and listen the difference.
Better way is just play and listen the styles right on Your KB.
Walid
Post by Walid »
I'm user of the version 1.
I'll need to export all the samples used for a custom drums kit (USR DK) to a wav files named with the keymapping : C1,D1,E1... each file contains the associated samples as played in the KB when selecting the voice.
Reason : I want to create / review styles in a DAW I'll need to create a soundfont file with my KB sounds on offline mode (without the midi connexion).
Could we do this with the new version ?
BR
You can export a whole DK as .wav with version 3+
