Korg Pa Manager Version 2.0
Sam
Post by Sam »
Congratulations with the latest development.
So now finally we're able to manage and swap samples between SETs? Aside from what's already mentioned (protected SETs...) is there any other limitation?
Re: Korg Pa Manager Version 2.0
Thanks. Yes now we can Get any Sound / DK including their related MultiSamples/Samples etc..
Other limitations..
Now that we can Convert a PA3X Sounds to PA2X/800, there are any compressed samples in use by the 3X set, then they will not be imported, Hence nothing other than a PA3X can play compressed samples.
Sam
Post by Sam »
ok..so besides protected and compressed SETs, everything else works for standard SETs.
yes, correct.
zardoz505
Post by zardoz505 »
Did i see a OS X version available for download ?
ElectroVoice
Post by ElectroVoice »
Hi Admin, I understand why compressed sounds are not editable because it may be in use for pa2x and pa800.
But will there be a solution to also edit compressed samples for users of pa3x?
Yes, an OS X Compatible version will be available in the next few days.
ElectroVoice wrote:Hi Admin, I understand why compressed sounds are not editable because it may be in use for pa2x and pa800.
Maybe and hopefully in future versions.
tahir1983
Post by tahir1983 »
Hi ! it seemes there is some problems with kmp import .... not any kmp can be imported .... and those imported ksf files are not correctly arranged in sample zone... in each zone located the same ksf sample ... this issue concern to kmps created by converting voices from awave studio ...
tahir1983
Post by tahir1983 »
and it seems it behaves so since 1503 update version ... please fix this .... and if it is possible will you make the software not to update automatically please ....
Wow, just realised last update messed up the whole MS Manager :/
UPDATE coming ASAP!
EDIT:
v2.0.1504 Released which fixed the problem.
Next time please post these in the Forum Bugs Section.
Thanks.
