That is not a bug.
As mentioned previously it's to do with the certain SETs that you are using.
Your SET may be perfect, but the other SETs that you are mixing it with/from have issues.
Can you post examples of what it should sound like and what it sounds like afterwards? That would help us understand the problem.
Or if you would like, please email customer support your SETs and we can take a deeper look.
We would need the original SETs before mix up and the final SET saved from PA Manager.
You can use www.wetranfser.com to upload the SETs.
After Merging sets wrong samples in sounds [RESOLVED]
Re: After Merging sets wrong samples in sounds
hi
Same problom here, when merging sets all samples missing, for example when importing a style from set B to A all A set sample missing.
Hi,TECH18 wrote: 01 Dec 2023, 17:25 hi
It sounds like your MULTISMP folder inside your set is missing the RAM.KMP file ?
LaurentiuTanasa
Same problem here!
If you're using Problematic SETs to copy from, then PA Manager can only copy the problematic sounds/samples.
You guys need to check your SETs prior to mixing.
LaurentiuTanasa
I managed to resolve the problem today, I arranged both sets in PaManager, the Styles from set1 in Favorite 1-6 and the Styles from set2 in Favorite 7-User 3, then did the same thing for the KBD sets, and then for the Sounds. Basically I moved them so that they do not overlap in position before the merging and then I moved them manually, one by one, not all at once and everything worked just fine after this procedure.
LaurentiuTanasa
Re: After Merging sets wrong samples in sounds [RESOLVED]
Definitely something is wrong combining PA5X sets...
I've also facing issues with pads which plays abnormally sounds, taken from other voices. I will make a video with these issues because it seems we are not believed without proves
