Is there no 24‑bit sample support?
emreuyar
Post by emreuyar »
Hello, the locked set I purchased for the Pa5X contains 24‑bit samples. When I open the set in the sample manager, the samples appear as 16‑bit, and when I add a sample and save, my keyboard no longer opens my locked set. My locked samples become unusable. When I create a new set and manually import a PCM wave file that I am sure is 24‑bit, it also appears as 16‑bit or is automatically converted to 16‑bit.
Ekran görüntüsü 2026-02-20 094600.jpg (59.37 KiB) Viewed 61 times
Ekran görüntüsü 2026-02-20 094627.jpg (99.13 KiB) Viewed 61 times
Re: Is there no 24‑bit sample support?
The PA5X Does NOT supported 24bit samples. Everything gets converted to 16bit and PA Manager only replicate that.
