Diferenta intre doua versiuni de KST
Salut.
Sa presupunem ca lucrez la un set de Korg PA5X, il termin, il salvez ca atare, sa zicem cu numele de 2025.10.15.KST .
Pana in luna curenta (ianuarie 2026) mai adaug ceva in acest set, cateva tonuri, cateva style-uri, cateva keyboard set-uri. Il export si pe asta cu denumirea 2026.01.10.KST
Ar fi utila o functie de incarcare si afisare in paralel a celor doua KST-uri, exact ca la functia de copiere dintr-un set in altul, dar de data asta functia va trebui sa genereze un KST cu diferenta dintre cele doua KST-uri... Adica sa exporte doar Style-urile, sound-urile si keyboard-set-urile noi dintre cele doua versiuni.
:idea:
English:
Let’s assume I’m working on a Korg PA5X set. I finish it, save it as is, let’s say under the name 2025.10.15.KST.
Up until the current month (January 2026), I add some more content to the set—several sounds, several styles, and several keyboard sets. I then export this updated set under the name 2026.01.10.KST.
It would be useful to have a function that loads and displays both KST files side-by-side, similar to the existing “copy from one set to another” function, but in this case the function should generate a KST containing only the differences between the two sets—meaning it would export only the new styles, sounds, and keyboard sets found between the two versions.
Re: Diferenta intre doua versiuni de KST
Thank you for the suggestion and explanation.
At this stage, I'm not sure this is a highly demanded feature. Korg PA Manager already provides Reports that can be compared between sets, and it’s also possible to open two PA Manager windows side-by-side to compare different KST files or copy elements between them as needed.
While the idea of exporting only the differences is interesting, it would add considerable complexity for a relatively niche use case.
That said, we do appreciate the feedback and will keep it in mind for future consideration.
