I want to add a pad from another set to my set.
That pad uses a drumkit that has a lot of user samples
While the pad only uses three samples
I don't plan on adding any more pads or styles from that set to my set.
And apart from those three samples, I don't need any other samples in that drum kit.
So I'd like to add an option to the pa korg manager that can detect unused samples that are in that drumkit and add an option to automatically remove them.
This option could be used for styles as well as pads.
Delete unused drumkits user samples
- IMG_20250224_153603.jpg (3.6 MiB) Viewed 33314 times
Re: Delete unused drumkits user samples
Thank you for the suggestion.
However, on a deeper level this will create much more confusing and problems when you try and mix multiple samples together.
It will break many Sounds and cause other linkage problems.
So please add an option that allows the user to replace only unused drumkit samples in the style with a factory sample without deleting them so that no samples are deleted.
You can already assign and change the Samples on a UserDrumkit to replace an User Samples with Factory ones.Msepehri wrote: 06 Mar 2025, 09:33 So please add an option that allows the user to replace only unused drumkit samples in the style with a factory sample without deleting them so that no samples are deleted.
Yes, but I don't know which drumkit samples are not used so I can replace them with a factory sample. Please include an option in the report style that shows which notes are used in each drumkit so I can manually change the rest of the samples to factory.
After deleting the unused samples, you can automatically rename the sounds and drumkits whose samples have been deleted to avoid problems in the future.
