Converting PA4x or PA3x style to PA1x
Discussion / SETs - All other models PA80 / PA1X / PA500
bataika
Post by bataika »
Is there any way to convert style from pa4x or pa3x to Pa1x? It says "style version is not compatible with this model". Can I do that at all or not? If I can, please somebody tell me how... :D :D :D
Re: Converting PA4x or PA3x style to PA1x
Conversion to 1X is not available. It's for 4X/3X/2X models.
miki67
Post by miki67 »
Hi, I have the following problem: all sets converted from pa4x to pa3x, once loaded the set in pa3x, I get stuck keyboard on some styles. I state that even converting styles only, the problem remains the same. with the previous version it happened, but not with all sets.
Thank you!
Stuck as in not being able to select those styles?
Can you please send those 4x styles to us, so we would take a look at the issue.
miki67
Post by miki67 »
Hi, I'll explain exactly what happens: I load the converted set
(also tried separately, first sound, then styles, etc) and when I touch a style (not all of them freeze) the keyboard locks immediately. I have to restart the keyboard. once it is turned on again, I touch the same style and it plays without problems, maybe for a few minutes, after which it stops again. I send you the original set plus the converted set. Thank you very much!
https://we.tl/t-zCzi9zRI4t
Thanks for sending them over.
Can we have the name/position of a certain style that always causes the issue?
This would help us save time rather than trying each style one by one.
miki67
Post by miki67 »
Good evening! Excuse me for only replying now.
Apparently, the converted set slightly exceeded the 256 mega ram memory. That was probably the problem, because when I converted it back with only 250 mega, everything went well. I'll update you if I find any problems here.
Thanks and best regards!
Thanks for the update.
