All KeyboardSets are messed up
Posted: 02 Jul 2025, 20:37
by valimaties
After combining two KSTs, I found that all the KeyboardSets present in KST are messed up... Practically, if the sounds are reorganised by the soft, the keyboard sets are not... and most of them contains other sounds than original Keyboard Sets.
Could you confirm it is a bug?
I load original KST, it is OK...
I load combined KSTs, keyboard sets are messed up.
Copy option used when combined multiple KSTs:
All options on, so even muted sounds are copied to new KST.
NO KeyboardSet are correctly set, every one is using other sounds!!!!!
What I'm doing wrong?
Re: All KeyboardSets are messed up
Posted: 02 Jul 2025, 21:01
by valimaties
Ok... I found that sounds are not copied (or are remaped) when copied and are not changed in KeybSets.
In this second image, UP1 (left) is probably from the second KST I copied, and was replaced into my main KST (from right - only loaded to see what was initially)...
Edited:
Ok, I don't understand some things:
What happens when you copy a style which have some sounds on some slots that are already occupied by some other sounds (same MSB-LSB-PC)? I thought the new sound it will be filled on a new slot, and the KSTs, or styles which use the sound from the objects in right part will be remapped to the new position of the new sound, does not?
Because, what is in my mind right now, the sounds are replaced on those MSB-LSB-PC, even if they were filled. So, an old KBD Set will use the new sound copied wrong into a position which does not belong to it.
Posted: 02 Jul 2025, 23:27
Hey,
What happens when you copy a style which have some sounds on some slots that are already occupied by some other sounds (same MSB-LSB-PC)? I thought the new sound it will be filled on a new slot, and the KSTs, or styles which use the sound from the objects in right part will be remapped to the new position of the new sound, does not?......
When a sound slot is already occupied, then it finds another EMPTY slot to add the sound and updates/remaps the Style to point to the new slot.
This has become quite a detailed post, so it might be worth that you reach out to us on the LIVE CHAT tomorrow (day time) so that we could go over what is happening as it seems quite involved.
We need to go step by step, as something isn't making sense with the SOUNDS not being copied/saved.
Everything gets copied fine when we run tests and no other user has similar issues, so it might be something SET related that we need to investigate.
Reach out tomorrow and we'll help you resolve the issue.
