VERSION 3.3.7301 Sound from pa4x to pa2x
tenny_pa4x
Post by tenny_pa4x »
Hi,VERSION 3.3.7301 does not work properly,i am converting from pa4x to pa2x and all the sounds in pa2x are mute...can i restore my PA MANAGER to an older version?all the settings are good in pa2x,KMP are loaded i can hear them only in the sound recorder but in user sound are MUTE
Re: VERSION 3.3.7301 Sound from pa4x to pa2x
There is no MUTE option with the sounds. Do you mean the VOLUME of OSC LAYERS = 0 ?
Can you please upload 1 or 2 Sounds so that we can take a look at the issue?
tenny_pa4x
Hi,my English is bad and I hope you understand,I know there is no Mute option,People that pay this money for PA MANAGER they know how to work with Korg Arranger.I have found the PROBLEM : After loadind the Sound into Pa2x I hear no sound in my speaker,because in MENU-AMP, the Amp LEVEL have the value =0
After converting I must take each Sound go to MENU Amp Level and set the Amp volume to 127 and I have many Sounds that have 16 OSC LAYERS
Just to confirm are we talking about Sounds that use ROM Samples?
Because those are set to 0 by default.
You can't be converting sounds from 4X to 2X that use ROM samples. The conversion works for RAM Custom User DrumSamples/Multisamples only.
tenny_pa4x
Hi , I am talking about sounds that use RAM Samples ,the older version from PA MANAGER was ok.
Will confirm / test and get back.
A new update has been released v3.37505 which should have fixed the issue.
