Hello everyone!
I have such a problem!
1. When I transfer the pads from the set to the set I need and save it, after I transfer the set I saved to Pa4X, the transferred pads do not work !!!
2. When I try to listen (play) in PA Manager - it gives an error !!!
s00000000000000
Automation error
Err @ 1240 @ SET__OS_PAD_MenuSelect
https://i.yapx.ru/LkRai.png
3. When I add the pads and samples I need directly to Pa4X from the set from which PA Manage could not transfer, Pa4X does it without any problems!
4. How can I go back to previous updates?
Intel core i7
ram 16gb
PA Manage error [RESOLVED]
- Скриншот 24-03-2021 215306.png (32.07 KiB) Viewed 8783 times
Re: PA Manage error
1) You will need to clarify this please. What doesn't seem to work?
Have you checked the Sounds & Samples used? If they're missing? More info please....
2) Can't initialize your Sound Card Device. Simple fix, is to re-install KORG PA Manager.
Re: PA Manage error
After reinstalling PA Manager, everything started working! ![Smile :-)](./images/smilies/icon_e_smile.gif)
