Drum kit problem after compress my SET
ANAFREE
Postby ANAFREE » 16 Feb 2019, 20:40
Hi , i have a problem in some of my drum kit started after compress my SET using Korg Pa Manager
see 00:15
https://youtu.be/dLc75PQNJMY
i must press SHIFT+START button to fix it (RESET midi signal)
i tried to remove loop option for any kit have a loop option, but the problem has not been resolved
Just if i edit the drum kit "which has the problem" and active "Single Trigger" option for each kit ,the problem disappears, but i think that's not a true solution.
note: the problem already exists on some of my style , so it's not midi or cubase issue.
Re: Drum kit problem after compress my SET
Postby Admin » 22 Feb 2019, 11:17
That sounds like an FX issue rather than a COMPRESSion issue cos it happens after it's played a few times.
Turn off your FX and check if it still happens.
ANAFREE
Postby ANAFREE » 22 Feb 2019, 12:56
Hi :) & Thank you admin
I think it's not korg pa manager bug, im sure it's korg bug because there some people have a same issue
Here's my topic on korg forum
http://www.korgforums.com/forum/phpBB2/ ... ce1c1b1ce6
another guy post
http://www.korgforums.com/forum/phpBB2/ ... p?t=117659
And some of my friends have the same problem and advised me to compress sounds samplers without compression of drum kit samples
I hope korg will fix that in the new OS
Thank you for your great servic, have a good day.
Postby Admin » 22 Feb 2019, 22:29
Not a PA Manager bug after all :)
Could you please Edit or Update your post on KORG Forums as you've mentioned the issue is caused after you've compressed on the PA Manager.
People might get the wrong impression and think the PA Manager is faulty.
Thank you.
ANAFREE
Postby ANAFREE » 24 Feb 2019, 13:51
Admin wrote:Hi,
Thank you.
Sure :) Thank you sir, I hope the KORG programmers will see my post on korg forum and fix that in the new OS, You can delete my topic if you want .
Return to “Bugs & Errors”
