Page 1 of 5
Feature Request [IDEAS]
Posted: 05 Apr 2014, 19:29
This Thread is now Locked and has been moved to a NEW topic.
Click here to continue....
Re: Feature Request [IDEAS]
Posted: 21 Apr 2014, 05:46
by Thoraldus
An audition function would REALLY be nice to audition changes to styles without needing to LOAD them each time.
Posted: 12 May 2014, 19:25
by Woody50
To be able to connect directly to USB port of keyboard - maybe even consider an iPad application version.
Hope these ideas help.
Posted: 19 May 2014, 19:33
by paul
Thoraldus wrote:An audition function would REALLY be nice to audition changes to styles without needing to LOAD them each time.
I would agree to this suggestion.
Paul
Posted: 20 May 2014, 21:21
by MamieNova
The tool (v1.00) is great. Some minor improvements would improve it a lot:
- Add the information Muted or not for Upper1/../Lower in STS
- Add a color code for STS which are different (different sound names) when they are copied/pasted from one set to another, because the user need to check and fix the bad conversion.
- Some operations take a long time so a timer information would be welcome (Applying sound change in all the variations of a style)
- Factory banks are not managed when present in a set. Why should they be moved as Favorites or User banks ?
- The conversion rules between PA3X PA900 and PA600 seem unclear. Could they be user editable ?
Thanks a lot for your tool which was missing to the community.
Posted: 21 May 2014, 13:40
-An AUDIOTION Feature would be nice, yes..
noted lets see...
-Muted/Unmuted Forst the Tracks,
noted.
-Colour Coding; something to think about...
-Some operations take a long time ?
Such as...?????? Things are quite fast, except some
REPORTS
-Factory Banks: These are not normally within a SET created Folder, so not planning any Direct support yet. You can still load them one by one to your Favs to do your tweaks and then you can reLoad them Manually to update their Bank positions, since the PA Manager would have changed it to a Fav Slot.
-Conversion Rules between: PA 3X / 600 / 900 ; There aren't none
All compatible with each other.
Posted: 21 May 2014, 22:56
by Sam
This is just a cosmetic issue in my opinion ...no big deal at all.
When you launch the program, it automatically loads the last SET that was loaded before. Instead, it be better for it to start up as an empty session with a list of 5 recent loaded SETs...? something like that.
Feature request for "Reports"
Posted: 23 May 2014, 15:51
by Sam
This is already a huge time saver. Just to improve it though, it'd be nice o have the page number of the bank included in the report.
Something like this:
Favorite 1:
1) Moonlight Ballad P1
10) Soft Ballad P2
etc
Posted: 23 May 2014, 23:17
Page Number of the Bank - Never thought of this, noted.
Posted: 24 May 2014, 07:55
by n_ninel
if you can do Export STYLE AS SMF and import. a great help with editing rhythms.
