Korg Pa Manager Version 2.0
Posted: 01 Mar 2015, 22:04
by Sam
Congratulations with the latest development.
So now finally we're able to manage and swap samples between SETs? Aside from what's already mentioned (protected SETs...) is there any other limitation?
Re: Korg Pa Manager Version 2.0
Posted: 02 Mar 2015, 01:27
Thanks. Yes now we can Get any Sound / DK including their related MultiSamples/Samples etc..
Other limitations..
Now that we can Convert a PA3X Sounds to PA2X/800, there are any compressed samples in use by the 3X set, then they will not be imported, Hence nothing other than a PA3X can play compressed samples.
Posted: 02 Mar 2015, 03:18
by Sam
ok..so besides protected and compressed SETs, everything else works for standard SETs.
Posted: 02 Mar 2015, 10:05
yes, correct.
Posted: 02 Mar 2015, 21:23
by zardoz505
Did i see a OS X version available for download ?
Posted: 02 Mar 2015, 22:19
by ElectroVoice
Hi Admin, I understand why compressed sounds are not editable because it may be in use for pa2x and pa800.
But will there be a solution to also edit compressed samples for users of pa3x?
Posted: 03 Mar 2015, 11:12
Yes, an OS X Compatible version will be available in the next few days.
ElectroVoice wrote:Hi Admin, I understand why compressed sounds are not editable because it may be in use for pa2x and pa800.
Maybe and hopefully in future versions.
Posted: 03 Mar 2015, 19:03
by tahir1983
Hi ! it seemes there is some problems with kmp import .... not any kmp can be imported .... and those imported ksf files are not correctly arranged in sample zone... in each zone located the same ksf sample ... this issue concern to kmps created by converting voices from awave studio ...
Posted: 03 Mar 2015, 20:14
by tahir1983
and it seems it behaves so since 1503 update version ... please fix this .... and if it is possible will you make the software not to update automatically please ....
Posted: 03 Mar 2015, 22:38
Wow, just realised last update messed up the whole MS Manager :/
UPDATE coming ASAP!
EDIT:
v2.0.1504 Released which fixed the problem.
Next time please post these in the Forum Bugs Section.
