Yes I know - that is the new things, but can You make the changes so that they will be now rocognize the PA1000 Musikant -let say styles?
From sound side - the Musikant not exporing any of the local sounds - maybe thay are all not for exporing.
If You need more information so i can upload them. Right now I just testing that .pkg on my KB without dongle chip but i think i should buy this one.
Korg PA manager and PA1000 musikant
Re: Korg PA manager and PA1000 musikant
Localised SETs on an SD are generally locked, which limits their usability.
Yes, but I asked the about the style side!
The Musikant addon add the to the KB a new "Musikant" section for styles, pads, sounds, kbsets.
All that added things are saved as "Local" in folders. Just asking - can You make that changes to PA1000 as well.
I will add the screenshots of the different situations and the sets (if i can).
- Loading PA1000 Musikant_styles_set (styles are in orig local).jpg (192.47 KiB) Viewed 41449 times
Now the styles are renamed as User.
- Reading PA1000 styles renamed as user styles.jpg (157.85 KiB) Viewed 41448 times
Now the Pads:
- Reading PA1000 Musikant Pads.jpg (132.24 KiB) Viewed 41447 times
And after renaming Local to user:
- Reading PA1000 Musikant Pads1.jpg (121.95 KiB) Viewed 41446 times
Here is the renamed style set
- Pa1000 Musikant Styles.SET.zip
- (3.33 MiB) Downloaded 2175 times
As you can see yourself, even after you've managed to load them, you'll still have errors, as the contents are Encrypted.
As much as I'd like to support Local files, it's something currently technically not possible due to encrypted content.
Hi!
Maybe I asked not correct (sorry my poor english). I just inform that there are now new areas in that PA1000 - Local (musikant or eastern)
I just asking: can you make these files (named Local) just so that your program will them recognize as Local without remapping them to Favorite or User.
If not, can you modify your program so that it will not asking the remapping those things and leave this alone and I can use the program normally.
- PA1000 Musi sty pad perf.set.rar
- (6.36 MiB) Downloaded 1978 times
