Update option [resolved]
Nemik
Post by Nemik »
Could program check on start up for new version.
Of course if.... must be possibility disable this function in Future Preference.
best was be : check for new version 8-)
Beside can you rename update files, now people has many KORGPAManager_Setup.exe, KORGPAManager_Setup(1).exe ...etc
not all know how check propetries of file.
was be nice if name was be like: KORGPAManager_Setup_v1.1.716.exe ;)
Re: Update option
The program automatically now checks for an update on startup.
There is no need to add an option if the user wants to update or not.
Every update is supposed to make the software better/stronger so users are obliged to update & benefit from the latest version.
The update has a solid name which cannot be changed. [industry standard procedure]
A user can change the name when they download/save the setup.
you should be deleting setups once youve installed the software, to avoid (1) (2) names etc...
Nemik
Re: Update option
Post by Nemik »
well... topic CLOSE [Solve] :)
