Multisample tab missing some info [RESOLVED]
etnomor
Post by etnomor »
It should be fine to have the size and samplerate info also at the list by MultiSample at the Sampler Manager.
Please add also the availability to sort this info.
Re: Multisample tab missing some info
The size is already there, but not too convinced that sample rate should be there.
If you do CTRL+I on a Multisample or RightClick > GetMultiSample Info it will present a Window with all the samples. Close it and head back to the SAMPLE Tab.
There you'll find all selected samples that are being used by the MultiSamples, which would show the SampleRate info.
etnomor
Post by etnomor »
Okay thank you. Because the the sounds to find on drumsamples and sounds, you can also find the samplerate there right? Multisample tab shows that info from there if i good understand.
