how to simply delete samples Topic is solved
erez83
Post by erez83 » 02 May 2019, 16:23
Hello
Thanks again for the amazing software
my question is
is their a way that
i can delete a sound and his samples will delete to
like im doing in the keyboard
when I delete the sound and then
i press in the sampler menu, and press
"delete non assigned to any multi..... "
Re: how to simply delete samples
Post by Admin » 02 May 2019, 22:37
A User Sound consists of MultiSamples.
Currently, you need to Delete the MULTISAMPLE(s) associated with the SOUND.
erez83
Post by erez83 » 05 May 2019, 14:45
what is the best way to do it
and from wich part of the software?
Post by Admin » 05 May 2019, 19:31
You can do it from the SOUND Manager or SAMPLE Manager.
Select the SOUND. Note which MultiSamples it's using. Click on the MultiSample tab and find the MultiSample.
Double click to edit the MultiSample. A new window will open. There you have the option to DELETE the MS.
erez83
Post by erez83 » 06 May 2019, 09:02
ok
thank you very much!
