Generate report PAD [resolved]
Nemik
Post by Nemik »
I having error trying to generate report in Pad Manager:
Run Time error '340':
Control element array element '10' doesn't exist.
Is happening when I try generate "SEQUENCE" or "HIT" report and happens on any pad set I tried.
Local and User is working.
Also after update today for ver.1.1 almost every times I open telling me message I running this program as Administrator and I should close and open again, when I click OK is open normally.
Re: Generate report PAD
Well spotted. Didn't realise this. Will fix in next update.
When you generate a report it generates only for the whole USER PADs. Not HIT separately, SEQUENCE separately etc..
So, for now to avoid the error, you can click on Generate report when you are on the USER Pads.
The Administrator message, It should only come up, after every few program runs not every time. It's just a warning. Nothing to worry about.
Nemik
Post by Nemik »
Also if you check on loading is asking me to overwrite banks, telling me I try load bank11 ???
Try I on Dopamine set.
all set is perfect working on Korg Pa600, but program is acting like something not right.
Nemik wrote:Also if you check on loading is asking me to overwrite banks, telling me I try load bank11 ???
No idea about the Dopamine set, but that's because maybe the Styles are NOT named accordingly in the STYLE Folder?
They should be:
Favorite01.sty
Favorite02.sty
etc..
etc..
etc..
Nemik
Post by Nemik »
I'm talking about pads.
You can download this set and try, then we see where is issue.
Nemik wrote:I'm talking about pads.
Then same goes for Pads. They need to be in correct order.
i.e:
PAD01.pad
PAD02.pad
etc..
etc..
Where would I download this SET from ? Can you provide a link please?
Nemik
Post by Nemik »
pads going like:
USER01.PAD
USER02.PAD
or factory like:
BANK01.PAD
BANK02.PAD
Nemik wrote:pads going like:
USER01.PAD
USER02.PAD
or factory like:
BANK01.PAD
BANK02.PAD
Ahh... its
BANK01.PAD
BANK02.PAD
Causing this.. They must be named PAD01, PAD02 etc.. and you won't receive the Re-Map box. ;)
Nemik
Post by Nemik »
just check my original korg factory set and....
You maybe want to check Korg Pa600 manual on page 158 before you disagree with me.
a little shame, you actually wrote program to support Korg pa files, and confuse on files names :shock:
..... no further comments......
Nemik wrote:just check my original korg factory set and....
Where is your SET? Can you provide a link please....
There is no confusion. That's just the STANDARD. When you create a SET from the keyboard, that's all it outputs. Anything else is extra and a REMAP Window appears?
