Multiple errors trying to import WAV files into sample manager (V3.1) [RESOLVED]
Posted: 06 Nov 2017, 16:19
I created a new set in the sample manager. I'm now trying to import some .WAV files. Every time I try to import one of the .WAV files I receive the message "Format Not Supported!". At the top of the error message window it says "Wav too big". This set of WAV files is between 6 and 70 MB each. I tried the smallest and that does not load. I have the model set to Pa4X (400MB).
I then tried importing some smaller sample loops that I have (average size 1MB) and they also fail with "Format Not Supported!". This time the message at the top of the error box says "8/16 Sample Rate".
I thought all WAV files should be supported, as long as they fit within the memory available. Is this not a valid assumption? I am using V3.1 build 4630 on Windows.
I've attached an example for each of the 2 types of failing WAV files.
Thanks,
Steve
Thanks,
Steve
